Use the following procedure to enable ARP on VLAN level.
ARP Field Descriptions
Use the data in the following table to use the ARP tab.
Name |
Description |
DoProxy |
Configures the system to respond to an ARP request from a locally attached host or end station for a remote destination. The default value is disable. |
DoResp |
Configures the system to send ARP responses for this IP interface address. The default value is enable. |
